Im currently doing a EICR report they have a socket in a airing cuoboard which used a to have a shower pump plugged now has the vacuum.charging. the distance from the bath is well within zone 2 but is in a seperate cupboard what C classification would you give this?
An interesting debate and back to the OP.
You are about to change a CU, adding rcd protection to all the circuits.... So maybe a note on the EIC is a sensible approach....
If the socket no longer needs to be there then I'd remove it, because this example illustrates folk will always be tempted to plug random stuff into unused outlets, even in an airing cupboard. In my own house, the washing machine is in the airing cupboard at the bottom of the bath. It was originally plugged into a socket in there, and I was happy to leave it like that until it was time for a new one. At that point I replaced the socket with a flex outlet plate and added a FCU on the outside of the bathroom wall. I also reversed the cupboard door so it is impossible to touch anything in the cupboard whilst in the bath. Some may argue that it would have been fine as it was, but I think I made sensible improvements. We certainly have nowhere else to put the washer in the house, and since the dirty linen ends up in the bathroom anyway, I like having it in there!
Interesting read. It does say he had an extension lead into the bathroom with his charger plugged in. Regardless of a socket in the airing cupboard or not it still does not prevent people doing such a silly thing it's surely down to the users discression in this scenario.
Kirkheaton
Business Name
EPC Electrical contractors LTD
Socket in airing cupboard
crotley32,
crotley32,
