The house is full of dodgy work performed by 'electricians'. None of my work has ever failed or killed anyone including showers.
Just out of interest... do all newly fitted sockets need RCD protection for regulations? If I RCD this it will be the only one in the entire house!
Obviously if safety were paramount the whole lot would need overhauled as you can see in the photo. The shower looks Ok though.
If you are competent as you suggest then you SHOULD know the answer to this question
a simple yes/no would suffice but I'll look it up!
so one RCD socket and 20 without then...
yes I know you are all good sparks who do stuff by the book as it should be but many are not as you know!
What is the socket outlet to be used for and what installation method, cable size, cable type, protective device and certification do you propose to use?
That is substandard work, you really should not be touching it because you are not qualified. If you were you would realise why everyone is jumping up and down on this forum.
I have some loudspeaker wire lying about and a condom for protection. I also have an old MOT certificate lying about somewhere.:beatnik:
Nocturnal....I'm the first to point out the stupidity of the regulations as far as 1 socket on an RCD for the sake of a reg number when none of the others in the place are.......but I think you've set yourself up for a pasting here....you've quoted for work you dont know how to do and then expect a forum to tell you how?
I love friday's here just love them
nocturnal,
edward cooper,
