N
nocturnal
RCD socket it is then,
it says 30ma on it, does that mean you can plug up to 30 things into it at once?
Yeah, you've got it!RCD socket it is then,
This fella catches on quick!RCD socket it is then,
None of my work has ever failed or killed anyone including showers.
Do you mind if I use that quote on my website? I'm sure it'll instill confidence in prospective customers!![]()
Hello,
I am wanting to install a double socket near the consumer unit (ref. photo)
Should I tap into the mains ring OR tap into the existing junction box as shown (says 'W/Machine Dish Washer Light on it)?
Obviously I'd need a fused spur unit if I am attaching to the existing junction box.
I didn't do any of this previous work, an electrician did.
Cheers
is the op suggesting that he's not a spark here?
I think this installation will be condomed as not compliant when an EICR is carried out
Wouldn't a correctly installed condom need to be IPx7
Something tells me the OP is already familiar with this forum...I know everything thats been said is right but the O.P would be forgiven if he thought this is an unfriendly forum which it is not. I interpret the fact that householders are allowed to add spurs without notification as a bit of commonsense as its well within a DIY task. not trying to ruffle any feathers just an observation...
