Discuss Socket not working anymore. in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
So last night I noticed that the Socket behind the TV was not working. Plugged in my Kewtech plug tester and nothing. So turned off the MCB for the downstairs sockets. Undone the Socket and its been spurred using new colours from the 13A FCU. Changed the 13A fuse in the FCU, checked the cables and nothing seems out of the ordinary.
There is a socket below that which is wired in Old Colours, which has been there forever. I am just wondering if there is an issue with the FCU, or the wiring itself.
Screwed it all back and then turned the MCB back on. Our house is currently wired in Old Colours, with a Square D CCU. Anyway plugged my socket tester in and again nothing. Would anyone have any ideas what it could be?
Is there any test equipment I could buy to allow me to do some testing, other than a Test Metre as i don't have a lot of money at the moment.
Is the FCU live? any idea where it is spurred from?
Where does the FCU wire to?
Ok. Pete beat me to it. And his is better English and more understandable... :disappointed:
The FCU is for an outside light. But the switch is broke. So I can’t turn it on to see if there is power going to it.
I may buy a new switch. Then see what happens with the new fcu in place.
That's different information from your opening post, it intimates that the faulty socket us fed from the FCU! Start again shall we? where is the faulty socket outlet fed from?
Comes from being from down South, tawt English, an spelin proper like immit
We all want to be like the southern men, with their skirts and man buns...
I’m just adding more information. To my original post. The socket is fed from the FCU. The FCU is for an outside light.
Have difficulty giving me a man Bun Spoon, ,ore hair on a gooseberry than my head.
i got a nice blonde wig going cheap. was for Mrs. Tel when she had chemo, but hers grew back. she now got blonde hair all down her back ( none on her head though :D :smiley: :confused: :hibiscus: )
Hi mate.
Ok, the bust socket is fed from the FCU. Where does the FCU get it's feed from?
You could get a cheap digital meter.
So you are an electrical trainee?
Does the feed for the SO come from the load side, or the feed side of the fcu.
You said you swapped the 13A fuse in the FCU that's what threw me, why did you do that? if its feeding the outside light?
New posts
Reply to Socket not working anymore. in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
