You could get a cheap digital meter.
So you are an electrical trainee?
Currently studying at college my C&G courses. What would you recommend something like a Fluke T5-1000 be okay?
Does the feed for the SO come from the load side, or the feed side of the fcu.I’m just adding more information. To my original post. The socket is fed from the FCU. The FCU is for an outside light.
You said you swapped the 13A fuse in the FCU that's what threw me, why did you do that? if its feeding the outside light?I’m just adding more information. To my original post. The socket is fed from the FCU. The FCU is for an outside light.
that would be OK for safe isolation and a rough guide as to voltage,amps and resistance measurements.Currently studying at college my C&G courses. What would you recommend something like a Fluke T5-1000 be okay?
you seen this mega beast 4+ tons.Hi mate.
Ok, the bust socket is fed from the FCU. Where does the FCU get it's feed from?
he's replaced it.Fuse gone in fcu?
MFT or separate testers. accuracy is king.
