Discuss Socket size for 5/8 earth rod driving nut in the UK Electrical Forum area at ElectriciansForums.net
universal earth rod tool.....
The "driving head" is whatever you fit into either the socket (usual) or the threaded end,to protect it from the impact forces of your driving tool/hammer/fist. I have an adapter that fits neatly over a 13.9 capscrew and fits into driving cup welded to a steel 'bit',that is driven by my old modified Hilti TE72. The capscrew is tough enough for several sessions unless you find a hard raisin in your pudding...i could tell you the size of my capscrew,but i would then have to ritually disembowel myself with a turks' dirk...the size of which is ALSO,a secret :thinking:
My driving stud which I've kept for years has a hex socket in the top of it rather than a bolt head, I think it was a 13mm Allen key before it got beaten to buggery with a hammer.
Reply to Socket size for 5/8 earth rod driving nut in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
I'm working on a system that has been installed incorrectly. It's a 3ph Hager board with 8 swa cables glanded into the bottom entry panel. The...
Short version: does code specify a minimum distance from the panel to the first grounding rod, and if so, what is that distance? Long version...
I have a large gym in the garden and it gets ridiculously hot in the summer. I have utilised pretty much every inch of space and do not want to...
