Discuss Solar immersion wiring, Sunsynk smart load in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
1animal1
Hi, I'm after some help please.
I have a 21 panel 8.5kw system with 5kw export allowance and a Sunsynk 8kw inverter. The inverter has a smart load ability which I'm hoping will save me buying an Eddi or isolar. From what I gather, this will let me set a surplus load to go to this smart load, so setting up 400w surplus to go to heat the tank for example.
My question is around wiring in the immersion. I assume I'll need a breaker between the inverter and immersion, but more importantly, I'm assuming I'll need to wire it through the secondary temperature failsafe switch? To make sure the temp doesn't exceed if the immersion stat fails.
Any help is very much appreciated.
Reply to Solar immersion wiring, Sunsynk smart load in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, Similar'ish question to my other thread but little more info now so a different approach but sorry if duplication. UK, single phase. Just had...
Hi all, I have a slightly mish-mash heating set up, in that downstairs I have wet underfloor heating with an individual thermostat per room, but...
Hi everyone, I have a quick question if I may? I'm thinking of adding a second PV system to my existing rooftop PV & battery setup. As the...
Hey all! I'm trying to install a smart switch to control my 3 outdoor lights. 2 wall lights and a lamp in the yard. The house was built in 53, so...
