Discuss Solder Joints in the UK Electrical Forum area at ElectriciansForums.net
a lot of it is prep though Archy with crimps...as with most things..
you can always bare off too much copper when prepping a cable end for crimping....so you cant get a purchase on the other cable your crimping to (when extending)....so basically it just pulls off....now i`v come across this one a few times when inspecting C/Us....should always perform a `tug test` on these whenever you find em when on an EICR....
Yeah, alright, but it doesn't take much effort to work out how much to strip and butt crimps have a 'stop' in the middle anyway.
Learnt to do solder joints at college. Our instructer said "here lads, show you this but you'll never need to do it".
He was wrong. Have used it on cable up to 10mm, (earths) when really neccassary and no way or time to do anything else. Have 100 % confidence in my abilities to whip and solder cable.
More to the point, and although i have used crimps on single solid core cable, i was always taught that crimps are only to be used on stranded cable as they grip better. Anyone else ever heard this?
It seems the "Sky" has "gorn orf". He/she seems to have wound up our spring and set us going. What does Sky think of the words of wisdom that we have provided him with?
I have a 1904 electricians pocket book with may words of wisdom on lots of things that are of only limited use to us today.
When in the merchant Navy we regularly used to joint the snapped flex on cluster lamps by knotting the flex( with a reef know of course). The bare wires were then insulated with vulcanising tape individually then over insulated with a fabric tape and then shellac varnish. They staid very flexible and I never had one fail. That's some thing else that you will never need to know.
Where are you "Sky"
Exactly,limited uses but useful on occasions,btw just read in the book that came with my new tester that care should be avoided that NO earth connection is made to any gas pipe.Before anyone panics my NEW meter is an EVERSHED & VIGNOLES circuit testing ohmeter made in 1941 that I bought at a show on saturday BNIB for £10
can we see a pic of that, phil?
here goes
IMG_0001.jpgIMG_0002.jpgIMG_0003.jpgIMG_0004.jpgIMG_0005.jpgIMG_0007.jpgIMG_0009.jpgIMG_0008.jpgIMG_0011.jpgIMG_0012.jpghere,s a few more of some of the other old things I collect,as you can see I also collect old torches and have almost a full set of the "ever ready motormate series" in the picture they are the blue ones.the only one missing is a motormate 2 which was square with an amber top rather than a red one made in the early 80,s the others date from early 60,s onwards.
Very nice. Particulary like the old avo multimeters. Now they were something else.
Used to use something similiar back in very early 80's not long after finishing my time when i worked in an electrical engineers. We had two, one calibrated every six monthes for use on post office work (now bt) and the other that our absent minded chief engineer used to regulary bu**er up. suffice to say we kept the better one hidden from him!
i'm watching a few avo 8's on ebay. mine is OK, reads comparable to digital meter and MFT .
I have 3 of the large AVO,s and they date from 1958 up to about 2005 and when tested they are all still accurate.
seen a few meggers on ebay....lovely wooden cases with glass vial surrounded by a brass bezel.....nice bit of wood that is.....its 50 quid......i reckon its 30s that...looks it.....
Where are you "Sky"
LOL - I'm here reading the pros and cons - think I will stick to crimps.
Reply to Solder Joints in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
I've always disliked needing to wrangle three 2.5mm T&Es into one 13A socket. The three solid cores rarely sit cleanly, and there's always the...
5K
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
