Discuss Some questions from school exam. in the Canada area at ElectriciansForums.net
N
Nikiter
hi there, im taking a electronics course right now (do it at home type) and im stuck on 4 questions that im tired looking answeres for.....so this is why im here....to get help and if somebody could explain me the answeres for them.....that would be awesome
anyways lets get to it
#1
In a 70V speaker feed system, which of the following voltages obtained from a tap on the line trasformer will cause 8Ohm speaker to consume 8W?
A. 6.3V
B. 10V
C. 5.6V
D. 8V
#2
A battery that you CANNOT recharge will contain
A. a acid electrolyte
B. an alkaline electrolyte (i believe this is the right answer but check me)
C. a carbon electrode
D. a nickel electrode
#3
If an 1100Hz signal and 6000Hz signal are fed simultneously to the input of an amplifier, the four requencies at the output (not including harmonics) will be
A. 1100Hz, 600Hz, 550Hz, and 3000Hz
B. 1100Hz, 600Hz, 2450Hz, and 3550Hz
C. 1100Hz, 600Hz, 4900Hz, and 7100Hz
D. 1100Hz, 600Hz, 9800Hz, and 24000Hz
#4
When an FM radio transmitter is modulated, what happens to the power output on the power output meter?
A. It rises slightly
B. It doubles
C. It remains constant
D. It falls
I would really apreciate your help.
Thank you all.
Reply to Some questions from school exam. in the Canada area at ElectriciansForums.net
M
Can someone please help with the following exam question revision. Have seen the same question twice now on two different exam papers and each...
zupos40
Z
T
I'm doing a mock exam for my 2377. The question is: An insulation resistance tester should be capable of: a) delivering a minimum voltage of 1000...
G
come across this one been stuck on it for ages please help also please tell me how you came to the answer as I can guess the answer but I always...
Z
Dear Friends I have booked my 2391 exam on October 18th for third time and this is my last chance to pass it. I have about five past exam...
15K
A
Paper 1: Sample Questions - C&G 2382-20 full 17th Edition paper A Got this from...
SirKit Breaker
S
