I am trying to find a sound activated switch which turn on an array of 240 volt LED security floodlights when an alarm siren activates.
My customer has a professional home burglar alarm system with an external sounder that goes off in the event of a home invasion, however there is no facility to connect it to his outdoor floodlights.
Therefore it seems to me that if a sound activated switch could detect the siren activating and turn on the floodlights it would be a way around the problem. Unfortunately I can't find a suitable one.
I am looking for a suitable sound activated switch together with, if necessary, a relay that would compensate the for the difference in load capacity.
I would greatly appreciate your thoughts and suggestions.
beter idea would be to use the sounder output to trigger a relay, 12V coil 240V 10A? contacts to fire up the lights. did one back in the early 90's, 20 500Watt halogens. relays supplie off a separate 63A MCB. 4 relays each with 5 lights.
Can't you use the 12 volts from the siren output to power a relay which in turn puts on the floodlights?
The siren operates by wifi, so there are no leads.
[automerge]1586623912[/automerge]
My problem there is that the sounder has no outputs, or inputs for that matter, as it is wifi.
i would imagine that the alarm panel may have a volt free relay built in . if so, this could be used
Dear all,
When I say the burglar alarm is wifi I should really have said WIRELESS as it works with its own wireless transmission and not through the home's wifi. I'm sorry I didn't make that clear.
If anyone knows how the Verisure (or in some parts of Europe it's known as Securitas Direct) wireless works, maybe I could hijack the signal it send the sounder?
any chance of a pic. of the inside of the panel, concentrating on the terminal strip ( usually at the bottom edge of the PCB ) ? most wireless panels have the capability of powering a hard wired sounder.
Dear all,
If you've not already, have a chat with the company that made it, or the person who installed it (if it's not the same as the company you've linked to).
[automerge]1586628123[/automerge]
The only other thing I can think of doing is possibly using some kind of current sensing on the sounder battery/power supply, but with low power sounder there may not be enough of a difference to be able to reliably pick up the current being used during an alarm.
The panel is a sealed unit.
[automerge]1586628718[/automerge]
Their rep said they make no provision for turning on lights and they don't want you to get inside their products which are all sealed.
I am back wondering if anyone knows of a sound activated switch?
You can get sound activated devices but you would need to confirm the db output of the sounder would activate it.
