Discuss Spanish home re-wire for friend? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I have a friend that wants a holiday home in Spain re-wiring. I've never done overseas work before so any tips on the regs I should know or what to expect or prepare for/avoid?
Thanks!
Hi all,
Thanks!
You would need to comply with the Regulations that apply to the country you are working in.
Appreciate your friend has approached you in order to keep costs down, but a local Electrician who is conversant with the local Regs.by laws etc would be a better option, you could always ask the Local Spark if you can help to try and keep costs down.
They tend to use singles in flexible conduit and radials fed from junction boxes rather than looping. Don't try and use twin and earth as it doesn't comply with Spanish Regs. due to the reduced size uninsulated earth.
I had a similar request a few weeks ago and after looking through the non-uk section on this forum I decided to pass. There seems to be a few ex pat sparks working in Spain though.
I have seen apartments being wired up in Greece
Didn’t look that complicated but be wary of hidden regs or possibly certification issues if your aren’t locally vetted and approved
Reply to Spanish home re-wire for friend? in the UK Electrical Forum area at ElectriciansForums.net
In 2019, I had a lot of renovation work done including a full re-wire of our three storey house. Before the re-wire was finished, we parted...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
