Discuss SPD risk assessment template in the UK Electrical Forum area at ElectriciansForums.net
I am due to carry out my first fuse board change under the 18th edition, i need a risk assessment template for SPD devices.
and with regards to AFDD i am under the impression i just need to recommend it in the quotation.
I doubt you will find anything like that at the moment, I haven’t the BBB, so what does it say?
Your last question has been asked a few times before, if you do a search here. Differing views on the subject.
If your in a Scheme, can you not seek guidance from them?
make you own.
column 1... Perceived risk.
( enter possible damage to It equipment etc. )
column 2 .... Recommended Action.
( install SPD/s to relevant circuits. )
column 3....Customer accepted/declined.
done.
make you own.
done.
IET Finger out time, stop sitting on the fence, Man up and get these issues sorted PDQ
need arthur scargill at IET, then all will be shut down.
No Tel the IET to stop publishing just for the sake of it, get their backsides in gear, be alive to the real world of Sparkying, get some answers, answered for the sake of sanity, no more ----- footing around, these Guys are supposed to be the Law makers , not copy writers, come on folks do the job you are paid for, I have know answers, cuz I iant smart bums like you folks, so get real and get things sorted, the IET look like a laughing stock, the 18th has been discussed, debated Theater shows, etc are you playing or just don't know, you are the Brains, or supposed to be earn your wages. stop taking Hard working Sparkies for a joke, they pay your fees, with the exorbitant prices we pay for YOUR publications.
Electrical installations in single dwelling units are not required to have SPDs installed, but their use is not precluded and it may be that in discussion with a client such devices are installed, reducing significantly risks associated with transient over-voltages.
Reply to SPD risk assessment template in the UK Electrical Forum area at ElectriciansForums.net
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
I try to keep out of Domestic work but I have a problem at home. Currently I have a wylex fuse board with re-wire fuses. they are great because...
4K
Hi, We're looking at installing solar at a remote property which is on a TT system with out buildings supplied with underground cables (Stables...
