Discuss Split flat board change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have just changed a CU as an example piece for Part P reg.
RCBO on each circuit except bell as in surface trunking.
I have some concerns.
1) Gas bonding.. this is other side of wall to supply and is NOT accessible anywhere else in building up to boiler. So bonded in boundary box ? OK ? Water no problem.
2) I have a light on ground floor entrance hall that IS NOT switched from upstairs but is in a 2 gang switch so when you cut power to DB on incomer this light is still on...
Just label Isolate elsewhere ?
ATB S
Reply to Split flat board change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hi all, I am a new home owner and have had a quote on some electrical work I wanted done in my home. I was wondering on if someone could give...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
