Discuss split supply in the Industrial Electricians' Talk area at ElectriciansForums.net
dogg
Hi all, went to look at a job today, the owner wants to convert a house into 2 flats, not done anything like this before. 100 amp fuse, TN C S supply
Can I split the 1 supply for the 2 flats, he would like a landlords meter put onto the second flat, so he could then work out the bill for each flat, each flat will have 2 x 32A and 2x 6A circuits .
Or have a new supply put in for the top floor flat?
why not install something like this in each flat, wont cost the earth and you can see if both meters match up to the distributors meter.
SIEMENS ELECTRIC METERS/KWH/ELECTRICITY/(ZEROED) on eBay, also Meters, Test Measurement Equipment, Electrical Test Equipment, Business, Office Industrial (end time 31-Oct-08 15:19:08 GMT)
i'd also keep an eye on the length/size of your tails. would be a lot easier for you to install a new DB in each domicile. i'd personally install at least a 6 way unit as each flat may need the provision for a boiler, cooker perhaps power showers, lighting & power.
Reply to split supply in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
Hi all, I hope you could share your experience and advice regarding supply 50 flats in 5 storey block of flats. We get 3 x 430A supply. What...
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
