Discuss Spotlights Measurements in the Lighting Forum area at ElectriciansForums.net
N
NathanMorgan
when measuring out spotlights in a kitchen what is your initial measurement from the wall to avoid shadows reflecting beneath cupboard units etc.
would you go 600mm/700mm from the wall to avoid this issue and then begin your spacing calculations?
Thanks.
min 3 ft. from walls. then plan middle row/s.
I like to come out around 700/800 where there are wall units over a worktop. Normally slightly less over a sink where there are no wall units. You need the light over the work areas.
The height of the ceiling and the height of the gap between worktop and bottom of wall cabs are also a consideration. Generally I go around 600-700mm out from wall for 600mm deep tops. Shadows are created on the worktops but adjacent spots either side usually reduce it.
thanks for all of your replies.
Another quick question, say im installing 10 spotlights and the length of the room is 3.5m and width is 2.5m.
I would divide 3.5m by 6 to give equal distances from each spot and divide 2.5m by 3 etc.
so 3.5m divided by 6 = 580mm.
say I need to bring this first spot out to 700mm due to kitchen units/worktops etc, how do I then modify my calculations for the other spots to be equal distances apart and the distances from walls?
Thanks.
Thanks.
I normally re calculate from the first spot out at 700mm, to the last spot out at 700mm, using them as the new edge of wall, if that make sense.
another top tip. play this whilst marking out. works every time.
Thanks.
Why divide by 6 when you have 10 lights,am I being a bit thick here.
Reply to Spotlights Measurements in the Lighting Forum area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
