Discuss Stair Lighting Problem in the Lighting Forum area at ElectriciansForums.net
vini
I wonder if any of you can come up with a solution to this issue.
I have stair lighting which is controlled by 2x two way switches and 5x intermediate switches. Each switch turns on and off the entire lighting in the stair. My customer wants to be able to limit the time the lights are left on as some individuals switch on the lights, go into their flat and forget to switch off.
Other than swap the 7 light switches for 7 timer switches at £20 a pop plus installing, do any of you know of a component which I could retro fit to do the timer job.
I had looked at this but not sure if it would work, waiting on Schneider getting back to me.
Staircase Timer Light Switch, 230 V, 1 → 7 min@ 50 Hz, 48 s → 5.6 min @ 60 Hz Setting Time
15363 | Staircase Timer Light Switch, 230 V, 1 → 7 min@ 50 Hz, 48 s → 5.6 min @ 60 Hz Setting Time | Schneider Electric - http://uk.rs-online.com/web/p/products/8968569/?grossPrice=Y&cm_mmc=UK-PLA-_-google-_-PLA_UK_EN_Automation_And_Control_Gear-_-Timers_And_Counters&mkwid=sobRHR8Wl_dc|pcrid|88056617643|pkw||pmt||prd|8968569&gclid=CjwKEAjwgtTJBRDRmd6ZtLrGyxwSJAA7Fy-hUnjh_rnl0YMdxBO9goJ8sHRZkYWY4AzfyqoGhZIV6RoCC7rw_wcB
You only need one timer, but will need to change the switches to a re tractable switch type. Alter wiring to type of switch being fitted
Reply to Stair Lighting Problem in the Lighting Forum area at ElectriciansForums.net
Hi all I am new to this forum and hope this is right placed and of interest. I would like to make a setup with one or more impulse relays...
Hi all. I'm currently renovating a house and have one particular requirement I'd like, if possible, sme suggestions. One of the things I would...
Squid
S
Having closed down my business and gone to employed, I have a garage full of unused stock..... Looking to get rid of it as one bulk sale, am in...
S
Hi All, just after a bit of advice with regards to using the following staircase timer from theben. ELPA 7 Just need to confirm that i can wire...
9K
E
In addition to my concurrent post regarding large farm install, have to concentrate right now on lighting scheme for the near to completion dairy...
electricAl
E
