Discuss Stand alone RCD's in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Could anyone give me a link to where I can buy a stand alone RCD? I have looked and looked and just find a lot of threads on the subject but cannot find anywhere that sells them. I could just fit an enclosure/din rail but I'd just like to see these stand alone RCD's and make a choice..
In this case it will be to protect lights on an old re-wirable CU as the customer wants some outside lights and prefers not to upgrade the CU. I could just use a RCD FCU, but at some point I know I'm going to come across the same situation for a ring main which I may not be able to find an RCBO for.
Cheers all..
best i can come up with is to stick it in one of these.
I new you'd be first to reply Tel :smiley2:, thanks..
Is that an enclosure with Din rail? Where did you find it?
Cheers.
In this case it will be to protect lights on an old re-wirable CU as the customer wants some outside lights and prefers not to upgrade the CU so I could just use a RCD FCU, but at some point I know I'm going to come across the same situation for a ring main which I may not be able to find an RCBO for.
Cheers all..
Hi Happyhippydad , I will stand to be corrected but I can not think of ever buying a " stand alone RCD " .
Just buy a enclosure with a din rail , or even a separate piece of din rail and cut it down to fit if needed and then fit an appropriate RCD for the task .
Edit ; Dam I type at the speed of a drunk slug !
Cheers.
it's wylex. screwfix and most wholesalers. couple of quid, and it's din rail. i'd not use the knockouts, though, drill separate holes for each cable entry. ( and before anyone mentions eddy currents, it's plastic).
you've been robbed. i bought 6 from electric center for about £12 inc. VAT.
Denmans (all about electrics.co.uk) also do an extra height one (for 1.79) that can be useful for RCBOs or just extra wiring space.
Thanks Richard, I think the extra space for the RCBO is perfect as thats what I would be putting in.
Hi Richard,
I've been looking (online) at the enclosures for a single rcbo but theres no mention of whether they include a Din rail. Just wondered if you (or anyone else) could clarify?
It doesn't look like they do, but that doesn't make sense as they look designed for an MCB/RCBO?
Just buy a length of Din rail as well then .
I think we pay just over £2 a length , so it shouldn't break the bank . And it is always handy to mount in the stores or even the back of the van just to keep all of the spare trips / contactors and relays in one easy to reference place !
Cheers all..
Use that RCD FCU for now. If you do find yourself in that situation with the RING FINAL not ring main, tell them they must upgrade their board or REFUSE to do the work. Simples.
The Denman ones have a moulded in plastic din rail, if you are going to have to fight to get the tails in then it may snap, if you are using it for a single RCBO then you should be OK.
There is no bus bar or earth neutral terminals in the enclosure.
pretty photograph for you:
Thanks as usual Richard :)
Just like to end the thread properly with a bit of feedback.
Found a place local to me which sold the same ones Richard. :) Thanks again..
I just need to find someone who wants some more sockets and doesn't have RCD protection!!!
Always good to have pictures:
View attachment 21417 View attachment 21418 View attachment 21419 View attachment 21420
i feel sorry for stand alone rcd's.
no mates to go for a pint with ,
microwave meals for 1 ,
no-one to banter with at work ,
you should at least get him a few jazz mags to pass the time with.
Reply to Stand alone RCD's in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Hi all, After some options/opinions on fault finding N/E fault on ring final as fairly newish to being out alone. Customer wants to upgrade from...
