Discuss Steel Conduit in the Electrical Forum area at ElectriciansForums.net
If its an exposed conductive part it needs earthing. if its an extraneous conductive part it needs bonding. If its neither it doesn't need earthing nor bonding.Hi
Just got a quick question. I install CCTV systems and want to start using steel conduit instead of PVC.
Do I need to ground the conduit if it will only have CAT6 network cable inside.
Think he's busy watching the vids Lee, he might reply in a couple of hours once he's woken upexposed conductive part- conductive part of equipment which can be touched and which is not normally live, but which can become live under fault conditions.
extraneous conductive part- a conductive part liable to introduce a potential, generally earth potential, and not forming part of the electrical installation.
That's a bit of a sweeping statement mate imo. If extraneous it would have to be bonded. There is no mention of how the conduit is installed. As its for CCTV there is a good chance the conduit could enter the building from outside. We don't know how the conduit is installed outside.No need to earth or bond.
I read it as the op was using it for cctv drops or in places where cables couldn't be hidden or clipped. I would be very suprised if these cctv steel conduit were buried and introducing and earth path into the building, as the cabling is cctv no dangerous voltage will be running through the conduit at most poE would be used still less than <50v or BNC sytem more commonly using 12v. If the op could give more detail to the exact use of the steel conduit then wee may be able to offer more unique advice to your post.
Reply to Steel Conduit in the Electrical Forum area at ElectriciansForums.net
