Discuss stereo and bell timer in the Commercial Electrical Advice area at ElectriciansForums.net
L
Lukethoma1985
Hi all. Hope your all having a good day. Does anyone know a timer that will operate to work a bell or siren with a stereo. To turn off the stereo and sound a bell for breaktime. Im having trouble. I cant find one that will work both. Thankyou. Luke
common, normally open, normally closed. magical thingies that switch things on and off when you apply or remove voltages from the coil/s. are you a spark?
Yh ive not been on here for a while, i dont think ive explained very clear. I knew what the NO and NC are because i do a few bugular alarms i.e. tamper usually NC but not sure how that would work. Bell needs to sound for a couple of seconds then music starts at start of shift throughtout the day then bell sounds and music stops at break time. Danfoss do a timer (pulse) but only works 1-15 seconds so good for bell but not stereo. They do another one which minimum time is 15 seconds so no good for the bell.
Reply to stereo and bell timer in the Commercial Electrical Advice area at ElectriciansForums.net
Hi All, Thankyou in advance for your help I have a block of 5 stories with a staircase timer already installed in a 3 wire connection setup. I...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
I’m switching out timer light switches for normal light switches in my bathroom. One went to a light and fan and the second went to another light...
Hi All, Bit of a tricky number. I have recently installed lights / fans /toothbrush chargers and shaver sockets to a bathroom and En-suite. The...
