- Dec 18, 2011
- 5,379
- 6,732
- 405,788
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
A customer has asked me to add some sockets. Whilst there she asked if I new what the lines running up the wall from her light switches and sockets were. They are slightly sticky to the touch and this is not recent work it has been in situ for some time.
The picture with the light switch to the left of the door is not great but if you look slightly above the door frame vertical to the switch you can see the mark.
The pic with the socket in shows the socket in the skirting board and you can see the clear vertical mark higher up by the side of the door.
Cables getting warm? Strange filler used? No idea!
