Discuss stud finder finds cable but need advise in the UK Electrical Forum area at ElectriciansForums.net
javidr
Hi
I have a wall where i know that there are some wires inside, as the electric installation of the thermostat is placed there.
I need to drill a hole in that area and obviously i want to avoid hitting those cables. I have bought a stud finder to see where can i drill the hole, but it "detects" wires everywhere in that wall, which is not correct.
Can somebody advise what can i do to find exactly where the wires are to drill the holes safely?
the cables should be directly abobe and/or below the accessory. sometimes horizontal. depending on what the wall structure is, hard plaster on brick or dry lined, determines on your method. with dry lining or studded walls, jost poke a screwdriver in. with direct plaster on brick, use a drill carefully to go through the plaster.once you hit brick, you know you've missed any cables
Hi - some additional information may be had by looking which way the cables run out of the existing thermostat. Assume all cables are live, so if you take the unit out you need to electrically isolate the boiler circuit and proceed with caution. Hopefully the cables go straight up the wall, +/- 100mm depending on how tired the installer was.
Reply to stud finder finds cable but need advise in the UK Electrical Forum area at ElectriciansForums.net
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Trying to find an armoured cable behind plasterboard and studding. It was used to supply power from the house but has been disconnected Can...
Hey everyone, I'm trying to understand how to fit a metallic back box on a stud wall. Should it be fixed to a stud (on one of the sides) or is it...
5K
