Discuss Stud finder recommendations in the Electrical Tools and Products area at ElectriciansForums.net
123
My old stud finder has given up the ghost, it was a cheap and cheerful no brand make but did the job I needed it for - finding studs & joists. Has anyone got recommendations for a replacement?
Had a play with an expensive Bosch one the kitchen fitter had and found it horrible to use.
you need one of these....
enjoy.
Reply to Stud finder recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
Hi all, I'm looking for a couple of PIR floodlights to replace old halogen ones, probably around the 50W mark would provide sufficient lighting...
Am absolutely gutted, my Fluke 1587 insulation tester appears it's had an unknown fatal incident. I was doing some testing a few days ago and was...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hi guys, Had an issue at a recent survey where doing a quick check and found we had pme with a reading of 0.44 ohms. Called the network and they...
