Discuss suplementary bonding again in the UK Electrical Forum area at ElectriciansForums.net
Yes, but it seems to be splitting hairs for dubious reasons.
Are we really likely to get a reading between 22 and 23 k
Ω?
If it were 22.1kΩ would you test the customer to make sure they don't have a low resistance?
I can't see what's dubious about what it states in the guidance notes.
It does seem a little odd though, if the body resistance is reduced from a dry resistance of approximately 1k ohm to a wet resistance of something in the order of 100 ohms which might be the case in a bathroom location.
Having said that it wouldn't be in the Guidance notes if there was a probability of shock.
Reply to suplementary bonding again in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Those week I have mostly been fitting 20 x 10W flood lights on the sloping edge of a converted mill ceiling, nothing is straight, nothing level...
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
My brain has been exercised a bit by this. Am I on the right lines with this extremely simplified example: If we take: -TNCS installation with a...
4K
So having a look at the electricians guide to the building regulations, section 7 safe working. 7.3 is about pre work tests and is states that...
