Discuss Supplementary bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
Cirrus
If installing a shower, is it compulsory to run a 4mm earth from lighting point to the shower? Obviously the shower circuit will have a 4mm cpc (10mm t&e). I understand that in an ideal world all extraneous conductive parts need to be bonded such as pipes but let's say that is all done and it is just a case of installing a new shower, is it necessary to take a 4mm to shower from light?
If its all been supplementary bonded ,then just run a 4mm earth from the cpc in the shower unit to the cold supply to the shower unit either internal or where it enters
I am assuming you mean that the light has also been bonded previous
the way i understand it you are supposed to link all the circuits in the bathroom to a cold pipe ,i.e.rad pipe.ammendment 3 ring any bells.:p
As long as all extraneous conductive parts are bonded and all cpcs in circuits in zones 1 2 and 3
If the circuit is outside these zones then no need
I am not aware of any reason why you mention bonding the circuits to the cold pipe The idea I believe is to make a faradays cage, so I see no reason to do that .
Hot cold+ rads pipes are all cross bonded either in the bathroom or local externa anyway
Could one of you tell me if there is a time period before being logged out automatic
I take so long to reply that I am struck out before I can zap the reply button
Will have to just look and observe if I cant speed up I suppose
You could always just install to the 17th, then you wont have a problem.........(probably)
And dont automatically assume a cold pipe is an extraneous path, it only is if it copper all the way back to the incoming
Reply to Supplementary bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
in the old bpg4 it stated Absence of supplementary bonding for installed Class II equipment where required (such as in a location containing a...
Curious about supplementary bonding, I have these two 4mm Cables loose and not connected to anything in my parents house. I presume they are for...
Just had my design project handed back to me from my last block and I got everything right apart from one question Q9 I would take a photo but...
