G
gixerpete
I have installed a new tap in my bathroom and have used a plastic connector, can I link the pipes across the connector?
If it requires supp bonding the put the link in like you say.
Was at a job yesterday where there was a plastic tee on the water supply. Just thought i'd check to see if there was continuity either side of the tee and it only showed as 0.02 ohm.
So much for plastic push fit totally breaking continuity
Was there water in the pipe when you tested it? if so the continuity would have been through the water.
