Search the forum,
Discuss Supply side L1/L2/L3 OR T1/T2/T3 does it matter? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
shoddyboby
Hello all.....Im Bobby ..I have been working most of my life doing domestic work and was wandering if you industrial electricians could offer me a little advice ..I have recently started working in a more industrail setting which is largely fine Its just from time to time I can get a little bit unsure for example I have been connecting up 3 phase isolators for ac units/condensers etc my understanding is that you would as a rule always connect ur supply cables to L1,L2,L3 however I was discussing this with a coleauge and he seems to think that you would connect to T1/T2/T3 .. would this be the same for contactors? anyone that could offer some advice It would greatly appreciated thanks
the L's are supply and the T's are load.
L1, L2, L3 i would generally expect to be line ccts as in supply.
Had one the other day which was R,S,T for supply and U, V, W for load side. Was an old inverter.
Often see U,V,W for motors nowadays
Thing is i absolutely make no assumptions and follow the drawing if i am wiring and labeling and use the manufacturers data sheets if i am fault finding.
To me:
L1 = LINE 1
L2 = LINE 2
L3= LINE 3
T1= TRANSFORMER 1
T2= TRANSFORMER 2
T3= TRANSFORMER 3
As I was trained in Electrical and Electronics before I went into bashing and denting other types of work...
Some Electrical Engineers that are on here will also see :
T1 = Tap 1
T2 = Tap 2
T3 = Tap 3 (of a Transformer secondary winding on the output reduced Voltage side)
L1 L2 AND L3 are always used by myself for marking/tagging/labeling my 3 phase supply inputs and cable break outs/boot off's...
The U V W that Plug and Sparks mentioned is on a lot of German hardware....
so yes stick to L1 L2 L3
obviously on the Electronics side of things,incase anybody smart pipes in...
L1 = INDUCTOR 1
L2 = INDUCTOR 2
L3 = INDUCTOR 3
That's just because I know some smarty will be itching to pipe in tuppence worth...
Got me thinking.... also seen L1,L2,L3, 4,5,6 etc becoming suffix A after the contactor and suffix B after the local isolater, e.g. L10,L11,L12 on supply side of contactor becoming L10A, L11A, L12A on load side then changing to L10B, L11B, L12B on load side of local isolater.
Reply to Supply side L1/L2/L3 OR T1/T2/T3 does it matter? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
