As above, place I work at as maintenance, had supply tripped off at the weekend. Not some stuff I’m fully conversant with, so just seeking views here.
3 phase DB supplying power and lighting for rooms, using RCBO’s. Panel has this as main switch;
The supply panel is this;
From what I can glean from the schematics, the supply panel breaker is 100A, and from the Eaton breaker it’s In is 250A, which seems unusual, two in series?
The supply panel tripped. No apparent reason. No one plugging in large loads, and no RCBO’s tripped. Breaker reinstated, and fine since.
Never experienced supply tripping like this. Cause for any concern, apart from me being there
