R
ringer
Customer has just had new driveway laid. Concrete drive alongside house with approx 100mm width of gravel between concrete drive and wall of house. SWA runs alongside house to garage (approx 4 metres) and has been clipped to external wall of house at depth of 50mm below top of gravel. Customer does not want to see cable above the gravel, nor will he consider burying deeper (not enough slack anyway).
I am considering adding a 'Warning buried cable' sign to the side of the house at about 50mm above the gravel. Would this be sufficient?
) it should be labelled as required by 542.3.2. Also minimum size of 2.5mm per Table 54.1. Can't see a problem otherwise.
