Discuss SWA cleats complying to 18th edition? in the UK Electrical Forum area at ElectriciansForums.net
Good evening,
I was wondering if anyone has seen SWA cleats that would comply with the 18th edition reg 521.10.202 (i.e. not liable to premature collapse etc...)?
The data sheet for cleats produced by SWAonline say they are 'stable' between -350c and 1050c but they are still made of plastic! Not sure that would be what I am looking for. All well and good using a metal plug and screw but surely the cleat with give up first?
Regards
Someone can correct me if I'm wrong but I highly doubt it that a firefighter will go into a building that is over 1050 deg C. I doubt their suits can that that temp.
Plastic is a bit of a Generic term.
Some plastics deform in warm water.
Some plastics have probably been to the Moon and back.
I'm reasonably convinced that SWA's quote about temps is either theoretical or a misprint, I'm not aware of anyone getting below -273c (absolute Zero)
Stability down to -35OC and up to 105OC constant
Maybe I'll tie it up with strips of fire fighters suits then.
Sadly I don't have time to write a list of the infinite amount of scenarios I would like to exclude from my question. But you have covered two there... It's not being installed under water or on a celestial body.
Ah the joys of Physics :)
Any idea of the price of those, larger P clips for MICC are certainly eye wateringly expensive. Though I assume these are steel and not copper!
depending on size of the cable. can use some black metal saddles if you got some. can get a bit pricey unless you get a job lot. it doesnt look that good though but at height its quite discreet.
It would help if manufacturers actually kept up with regs updates and developed products to allow us to easily comply with updated editions!
Tray and steel ties all good for commercial, but I can't see a domestic customer going for that look!
Reply to SWA cleats complying to 18th edition? in the UK Electrical Forum area at ElectriciansForums.net
Just wondering how your guys observe the reg, for preventing premature collapse of cables in plastic trunking, when securing to plasterboard, i.e...
4K
Hi all, I had the following situation arise and was just wondering what others’ views were Doing a new build, started November last year...
5K
The Ghost
T
Many will by now have heard of the new requirements for private landlords, enacted under Statutory Instrument 2020 No. 312, known as ‘The...
13K
Just a rant regarding all these landlords EICRs that have become the in thing. And maybe a word of caution to all of you doing them. To kick off...
11K
Regarding the above regulation, it is now a requirement that in the event of a fire ALL wiring systems now need to be designed and installed to...
20K
