Discuss Switch Fuses for fridges etc... in the Australia area at ElectriciansForums.net
SSE
Was always under the impression these were used as a means of isolation if work was to be carried out on fridges etc instead of having to pull them out from uderneath worktops So was a bit surprised when seen a high level (worktop height) switch fuse and low level socket for a fridge/freezer today at a job when there isn't even a worktop goin to be where fridge/freezer is? Would a low level socket without switch fuse not be adequate seen as it's easily acsessible?
So could the switch fuse be done away with? Does it need to be installed or will a low level socket do?
would the socket at low level be positioned behind the appliance? if so it could be argued the it is not accessible as the appliance would have to be removed in order to isolate it. For example if the appliance started to smoke you wouldn't want to start trying to move it about to turn it off.
If your socket is not directly behind the appliance then the spur can be removed.
The appliance hasn't actually been installed yet so i'll ask the customer tomorrow where it's going to be positioned. Thanks for your help.
If the appliance is not integrated then as far as i am concerned it can go behind.
However, with washing machines etc i usually out them in an adjacent cupboard for obvious reasons.
Reply to Switch Fuses for fridges etc... in the Australia area at ElectriciansForums.net
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
I wonder if any one can give me some advice. I live in a fairly new build house it's 11 years old. In our kitchen there is a fused spur switch on...
5K
  • Locked
5K
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
