Most 'experienced' sparks who earth their SY braids 9 times out of ten would know that when a question is asked such as; "Is it a requirement to earth the screening on SY cable?" The answer is no!
Best practice and requirement are two entirely different things, a point I seem to have to stress here on a REGULAR basis!
The OP's question has been answered I believe, and as for the sly digs and ridicule for suggesting something hypothetical, a little controversial but entirely accurate, I've no more time for it. Enjoy the rest of your rants.
We live in an industry where new developement, practices and technology constantly change so as for SY which in most cases is been used for a function to which it wasn't originally designed thus regulations have to catch up, think of the new section within the 17thh that were absent from the 16th but there is an overlap period where what you may be doing has little or no direct regulation regarding it, in these circumstances you need to make that judgement call and however you look at SY if using LV through it it always will require the braiding to be earthed ..... whether you use the terminology 'requirement' or 'recommended' its a matter of the obvious dangers that could exist from not doing so .... the regulations are ever evolving and always playing catch-up.
Also SY has a specifically designed gland for its termination that would make it exposed metalwork now if you were to utilise other glands that lose a specific function of the earthing of the original gland then its down to you to make steps to re-establish the earthing lost by say using a standard stuffing gland....
People are using SY for purposes other then originally designed
people are using glands not designed for use with SY
If you do either of the above you need to know the cable is suitable for the alternative use and that any other functions the correct glands performed other than giving a cable entry/clamp will be still achieved by other suitable methods.
This is why we can't quote a specific regulation for this situation but the more it migrates to other users the more chance we will see it included in the next amendments or even 18th edition.
Until then its common sense to earth the braiding and judging by what i find on site there is a massive lack of it, yes i know its not specifically a direct requirement but other broader regulations do cover the fact that it poses a danger if unearthed.
So 10/10 times when used with LV power i say it is required to be earthed.
PS i know you are not saying dont earth it and see your angle but it may misguide the less experienced in the industry by stating its not a requirement without expanding on that.
