I quote:
"An exception to (i) is permitted
(a) for a specific labelled or otherwise suitably identified socket-outlet provided for connection of a particular item of equipment, or
(b) where a documented risk assessment determines that the RCD protection is not necessary."
So I interpret this as a label on the said socket outlet or a risk assessment - now where's my label printer!
Back to the OP if I may..... did you receive clarification from the electrical contractor as to why these boards are deemed to be necessary of replacement ?
Hi,
I will ask our operations manager when she comes back off holiday what they have actually said.
thanks
Acestu
Hi,
thanks
Acestu
You say in post #20 the advice is from a firm that does your testing. Any issues should be detailed in the last EICR they provided.
Hi guys,
I managed to get hold of the condition report and on the front page under:
E: Summary of the condition of the Installation,
good, however some fuse boards (DB's) require updating to include rcbo's to bring up to date with current regulations.
What do you think guys ?
Acestu
Hi guys,
Acestu
that's a load of bollox. if the boards are safe for continued use, then there's no requirement to replace them in any regulation going.
Hi,
Thanks for the 2nd opinion, we are a registered childrens charity and money is really tight at the moment so we could do without giving him £900 for no reason.....
cheers
Acestu
£900 to do 5 boards. I'd bite their hands off!
Hi guys,
Acestu
Totally unnecessary work generation.
In other words they are rip off merchants, time you got a reputable company in. I hope they haven’t been paid for the EICR.
Why? £900 for unnecessary work when it isn't your money!
Hi, Richy, Tony,
The price maybe cheap but does the work really need doing when the boards have been fitted by qualified electricians to the current regs when fitted ?
Acestu
On the basis of what's been said, it doesn't sound as though the work is required. I was merely commenting that the amount of work suggested for £900 was cheap IMHO.
No probs Richy, I think we can afford to wait till we get some money for the work to be done, after what everybody has said on here
Thanks all
acestu
T&E Sub Main
Thread Tags
acestu,
acestu,
