nice one, i'll check and see how long they are :)
They go from 4mm to 19mm according to Fluke - Not sure what the depth of the RCBOs involved are but that should be enough I would have thought.
They don't actually advertise them as GS38 Compliant, perhaps because they aren't spring loaded so wouldn't comply when retracted. However, that's no different to the older Megger ones with removeable covers. These are far more convenient because you don't immediately lose the covers...
It's surprising how often my old GS38 tips were defeated by a recessed choc block terminal..
They do them as whole test leads too, but I prefer to have the leads separate for a break out box.
I'm old fashioned I just shove a 3.5mm accessory hole down the recess, no I'm not joking.
Extract from the manual:
RCD Tripping Time Measurements In this test, a calibrated fault current is induced into the circuit to cause the RCD to trip. The meter measures and shows the time required for the RCD to trip. You can do this test with test leads or the mains cord. The test is done with a live circuit.
And while the mains lead is plugged in, there are plenty of other test that can be carried out at the same time, may not be convenient for all RCBO's, but will be for the majority.
set of 40 year old AVO 8 probes. 5"long and only 3mm diameter.
Nice one, I really appreciate that, I'm gonna check these out,I have a feeling that at 19mm it still might struggle.
I just ordered a set of the Fluke TL175E Twist guard 4mm test leads to see how well they work. They look neat, even giving you a little window showing the CAT rating & voltage for each level of exposure.
A sort of test striptease!
