Discuss TEST LEADS FOR RCBO TESTING in the UK Electrical Forum area at ElectriciansForums.net
And while the mains lead is plugged in, there are plenty of other test that can be carried out at the same time, may not be convenient for all RCBO's, but will be for the majority.
They go from 4mm to 19mm according to Fluke - Not sure what the depth of the RCBOs involved are but that should be enough I would have thought.
They don't actually advertise them as GS38 Compliant, perhaps because they aren't spring loaded so wouldn't comply when retracted. However, that's no different to the older Megger ones with removeable covers. These are far more convenient because you don't immediately lose the covers...
It's surprising how often my old GS38 tips were defeated by a recessed choc block terminal..
They do them as whole test leads too, but I prefer to have the leads separate for a break out box.
Nice one, I really appreciate that, I'm gonna check these out,I have a feeling that at 19mm it still might struggle.
I just ordered a set of the Fluke TL175E Twist guard 4mm test leads to see how well they work. They look neat, even giving you a little window showing the CAT rating & voltage for each level of exposure.
A sort of test striptease!
Reply to TEST LEADS FOR RCBO TESTING in the UK Electrical Forum area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Ring main was on a c40 rcbo so I tested the circuit everything was fine and dropped down onto a b32, It’s quite a long circuit but only serves...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi, Just been scratching my head about this one and wonder if I've missed anything. A few weeks ago I installed a new circuit for a 3kw oven and...
Bloody specific fitting megger test leads! I've lost 2 of my megger probes now. I have plenty of crocodile clips and the long, thin, bendy probe...
