You will need to be aware of fakes when you buy after market, test leads need to compliant with GS38, so be warned, apart from being dangerous if they are not GS38 compliant could make your test results invalid, just saying.I need new test leads for any Metrel and have seen AMECal do the same set as Metrel. Just wondering if they are any good or should I stick to the pricier Metrel ones?
Thanks in advance
How so? I thought that GS38 was to do with safety, not accuracy (not looked at it recently).if they are not GS38 compliant could make your test results invalid, just saying.
Just thinking that if the leads aren't GS38 and some jobsworth asked for a check of the equipment used, and there was an accident or mistake the non conforming leads could be an issue, may be my wording was a bit vague.How so? I thought that GS38 was to do with safety, not accuracy (not looked at it recently).
