- Reaction score
- 17,090
Time to find another job I think, the QS sounds like a complete prat. You will probably never see eye to eye with some who clearly shows complete incompetence.
He sounds like a right jobsworth.
Discuss test results question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
For sure. Crap situation though for the OP.
All he says to me is that my results aren't right when he calculates them
Needless to say I have been stopped from testing because im such a headache for him
He said to me that maybe I should read the osg to refresh my memory on testing, and I corrected him by saying "don't you mean gn3?" He didn't even know what a mantell unit was either
No the qs basically took all th testing and gave it to another guy to do, to be honest I'm not that bothered he can have all the grief about it as I'm not listened too and talked to like I'm fresh out of my apprenticeship
I feel like the good ones mostly get looked over and the bad ones go on to get the authority
They wont be, he is obviously a numpty. Measured test results will always be a tad lower than calculated due to parallel paths, and in some cases they will be a lot lower.
Tell him to leave it to someone who knows what they are doing.....YOU, and advise him that he needs to do the Insp and test courses.
Cheers..............Howard
I thought you had to have your 2391 or 2394/95 to be able to be a QS? I had to provide proof of them in order to become QS at my current company
fair to say Chris your QS is a total bellend and he's done you a favour, I've never had the NIC bloke come and demand that all the results must be bang on calculated values, so ontop of the bellend QS there's a bellend NIC bloke (surprise surprise) I'd crack on with the install work n leave him to it cause sooner or later he'll fudge some results that'll land him and the muppet that's happy to test for him up in court
Reply to test results question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
