Discuss Tester probes for use with Wago's in the Electrical Tools and Products area at ElectriciansForums.net
Hello All,
Just wondering which types of tester probes you all use for testing on Wago connectors?
The probes on my MFT and multimeter do not fit through the small hole incorporated in the connector for testing. I am using a very fine needle type probe at the moment but would prefer something a bit more robust.
Any recommendations?
Thanks and ATB
Chris
root out a spare probe/lead and grind the point down.
Thanks for the replies.
I did think about grinding down an old probe, nice to know it's how someone else would do it.
My voltage indicator does the job perfectly, it's when I come to test using my MFT that the problem starts.
Test wise, the most common one is ZS on lighting circuits with neutrel at the switch and ceiling lights that are difficult to reach or have had the earth not connected/cut off.
ATB
Chris
so short out L-E at the light ( power off, of course) then use method #2 as portrayed by richard burns .
I’m interested in getting hold of some of those super skinny kewtech leads.
But where from?
I can’t find them anywhere.
I find it odd that such things are not readily available?
Reply to Tester probes for use with Wago's in the Electrical Tools and Products area at ElectriciansForums.net
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
I've managed to mainly fix a Megger 1502 MFT that was so far out of calibration it got laughed out of a tester day. I have high current loop. rcd...
  • Locked
5K
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Hi all, just a quick one to ask about an issue I'm having with my EV charger. I'll give a little background first but ultimately I want to know if...
