I have acquired an old British Thompson Houston 1/3 HP BKS 2410 single phase motor on a pillar drill, it needs new bearings before I can test run it, my question is can I use a multi meter to check the windings and find out if its a go-er at this stage and worth restoring ?
If so how ?
better with a continuity/insulation tester.
If so how ?
Rufues Do you have a meter and a megger and are you an electrician
[Q
Megawatt is just showing his age... I still call 'em Hoovers !
UOTE="Zerax, post: 1574476, member: 117522"]
Megawatt is just showing his age... I still call 'em Hoovers ! I'm probably older than Mw and even I know the difference between a Megger and an Insulation tester, as should you.[/QUOTE]
Nonsense
Milton Keynes
Business Name
1971
Testing an Old motor for restoration ?
DIY Electrical Advice
Thread Tags
Rufus2502,
Pete999,
