Discuss Testing an Old motor for restoration ? in the DIY Electrical Advice area at ElectriciansForums.net
I have acquired an old British Thompson Houston 1/3 HP BKS 2410 single phase motor on a pillar drill, it needs new bearings before I can test run it, my question is can I use a multi meter to check the windings and find out if its a go-er at this stage and worth restoring ?
If so how ?
better with a continuity/insulation tester.
If so how ?
Rufues Do you have a meter and a megger and are you an electrician
Rufus you really need a megger and a meter but the megger is the best way to really check your windings
An Insulation Tester you mean Mate a megger is a trade name, may be different over the water though.
[Q
Megawatt is just showing his age... I still call 'em Hoovers !
UOTE="Zerax, post: 1574476, member: 117522"]
Megawatt is just showing his age... I still call 'em Hoovers ! I'm probably older than Mw and even I know the difference between a Megger and an Insulation tester, as should you.[/QUOTE]
Nonsense
Reply to Testing an Old motor for restoration ? in the DIY Electrical Advice area at ElectriciansForums.net
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
My beko will not run, it attempts to move in both directions with a belt or not fitted also shows no faults in checking with a meter across its...
I posted a month ago regarding a single phase motor + panel I have been given to try and sort following water damage to the panel. The assembly...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
