Discuss Testing pyro 2L2.5 cpc size in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes, the sheath CSA is bigger than that of the line conductor for all multicore MICC as far as I know so will be the correct size. It's only the method of connecting to the sheath that may restrict the size.
It think the larger single core cables have a sheath CSA smaller than the conductor.
Reply to Testing pyro 2L2.5 cpc size in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello everyone, I saw in the hospital every circuit has 2 separate cpc, same size, sometimes different. I'm wondering. How we can do the dead...
Hi All, As mentioned, I’ve got what looks like a TNCS system but CPC is coming via an earth rod???? Not tested TNCS system yet to see if earthing...
Refurbishment of dwelling has taken place and the clients insurance company requires a periodic inspection and test to be carried out, A new...
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
Hi , I’m going install a commercial 450mm extractor fan , what size and type of cable should i use ?
