I was recently watching John Ward's video series on Electrical Installation Testing. In the part where he discusses measuring Ze, he states that you only test the earth connection to the cut-out and need to disconnect it from the bonding and the CU to do this correctly. In his example diagram he showed a seperate MET which made this simple to do.
The attached photo is my own house's supply cut-out, installed in the early 80s when the house was build. As you can see, the CU, the Water Bond, and the Gas Bond, are all connected together at the cut-out and there are no accessible terminal screws. There is also no seperate MET.
I have no need to actually test anything, but I am curious to know how a professional electrician would perform a Ze measurement if he encoutered this arrangement?
