T
TPES
This morning started with the plumber onsite rushing about trying to find a leak that was dripping from the newly plastered and painted ceiling in the corridor.
His pad saw came out and he started hacking away at the ceiling, he then started jumping about on his steps shout "I just got a shock"...
I thought...dont be daft.. theres only coax above the ceiling just there...
other trades soon gathered in the corridor to see what all the fuss was about.. So i got out my fluke volt stick and just touched the sides of the plasterboard and my stick shown it to be live...!!!
I then went across the surfice of the ceiling and it shown live about 5ft either side of the cut out plaster where the plumber had found his leaking copper joint..
Put my tester on the copper pipe work and that was not live, only the ceiling was live, even 10" down the timber door frame shown live!!
I new it was conducting through the water that was leaking, then spreading across the ceiling... I just couldnt figure out why... after alot of head scratching i decided to investigate in the ceiling.
It turned out to be a screw through the plasterboard on a traped cable....
Plasteres dont have a minute to live... goes to show bragging about the speed of your work doesnt mean a thing..
