Discuss The metal thingy for spacing drill in the UK Electrical Forum area at ElectriciansForums.net
Lost my thing as above, you know the thing bent metal thing with two holes spaced for doubles and an extra hole for duals tried umpteen search terms but all I get is the pattress and drywall template any ideas
P
Has somebody been at the uisge beatha?Lost my thing as above, you know the thing bent metal thing with two holes spaced for doubles and an extra hole for duals tried umpteen search terms but all I get is the pattress and drywall template any ideas
P
How much does that little lot come in at, looked at the vid am impressed.
even grinder and cold chisel is quicker, i dont know where my bolster is i just end up using a cold chisel instead either by hand or in sdsseen 'em all. bouncing off the brick. 110V SDS with scutch chisel does it i 1/4 the time.
if it is before plaster does it matter if there are a couple lines?I find them ok, I would rather use one than a grinder for cutting a box out neatly.
fine if you need to cut through into next door. scutch is far better.Hammer an bolster with plenty of guts behind it normally works for me. hee hee.
Reply to The metal thingy for spacing drill in the UK Electrical Forum area at ElectriciansForums.net
