Discuss this really puts the plum in plumber. in the UK Electrical Forum area at ElectriciansForums.net
You're book doesn't matter, the gas rules make a differentiation between sockets and cables.
50mm from cables and if my memory serves correctly it must be 100mm from sockets
If correct that calls for a reciprocal 7671 reg surely. The people who write the regs should talk to each other.
Did you cost 300 to install the wall socket? Why install it behind the pipe when space is at the side of the pipe? I think you cause trouble for customer making difficult to use the socket.
Lol, that was the funniest post I've seen in a while but I think you misunderstood the thread Jaris. The idiot plumber installed the pipe over the socket ;)
Reply to this really puts the plum in plumber. in the UK Electrical Forum area at ElectriciansForums.net
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
I'm following a spark who used an existing Panel Heater circuit, for new gas boiler circuit 6 months ago. The panel heaters were removed, so it's...
6K
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
