Discuss this really puts the plum in plumber. in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
went to a customer of mine today, she has just has a new boiler fitted. she phoned me as wasn't happy with the wiring the plumber had done connecting new boiler, programmer and wireless thermostat receiver to the existing y-plan wiring centre
he had also added the fused spur below the boiler as original heating system was plugged in to a switched socket.
what an absolute mess cables were clipped like washing lines across airing cupboard, cpc used as satisfied in cylinder stat , cpc used as ch on in programmer nothing sleeved up either to make it worse , 13 amp fuse in switched spur, existing 2.5 meb to gas and linked of this with a bit of 4mm to water. needless to say I ripped the lot out started from scratch and run in the new 10mm meb to gas and water and to top it off look at his gas pipe for the new boiler straight in front of the 2gang socket in the kitchen. The plumber had also issued a niceic domestic installer MWC for the work he done!!! looks like this scam will give any 1 a membership.
no she is paying for it, luckily she has only paid the deposit and hasn't settled him up yet. he was reluctant to come back as was saying that's nothing wrong with it. he is going to come back and move the gas pipe (if he wants the rest of his money) and shes going to deduct 300 notes as the cost of having me out to correct his wiring lol
Did you cost 300 to install the wall socket? Why install it behind the pipe when space is at the side of the pipe? I think you cause trouble for customer making difficult to use the socket.
If that's a gas pipe then it certainly does not comply with gas regulations ( law) so a quick call to gas safe will drop him in some rightly deserved excitement
Reply to this really puts the plum in plumber. in the UK Electrical Forum area at ElectriciansForums.net
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I'm following a spark who used an existing Panel Heater circuit, for new gas boiler circuit 6 months ago. The panel heaters were removed, so it's...
6K
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
