L
Leesparkykent
went to a customer of mine today, she has just has a new boiler fitted. she phoned me as wasn't happy with the wiring the plumber had done connecting new boiler, programmer and wireless thermostat receiver to the existing y-plan wiring centre
he had also added the fused spur below the boiler as original heating system was plugged in to a switched socket.
what an absolute mess cables were clipped like washing lines across airing cupboard, cpc used as satisfied in cylinder stat , cpc used as ch on in programmer nothing sleeved up either to make it worse , 13 amp fuse in switched spur, existing 2.5 meb to gas and linked of this with a bit of 4mm to water. needless to say I ripped the lot out started from scratch and run in the new 10mm meb to gas and water and to top it off look at his gas pipe for the new boiler straight in front of the 2gang socket in the kitchen. The plumber had also issued a niceic domestic installer MWC for the work he done!!! looks like this scam will give any 1 a membership.
