Discuss Timed outdoor lights trip..then they don't? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
New to this forum. I have a weird scenario and wondered if anyone might be able to help.
I have a Grasslin timer socket switch (not digital) in my garage. This powers 4x lights outside my house. I have 70 Watt bulbs in each. When they are set to come on, at 6pm, it trips the entire fuse box in the garage. The fuse box powers lights in garage, three more lights above each garage door and the three electric garage doors. When I flick the trip (note it's not the trip for the lights but the whole board) it all works fine. We've cleaned and checked all connections to lights, seem to be ok, would this mean the timer is the problem or are the light bulbs too strong? It doesn't make sense that the timer causes the trip yet it works as soon as the main fuse trip is turned back on. Any help much appreciated.
if it's RCD tripping, i's be looking for water ingress in the outside lights.
could well be. conductivity of water is extremely erratic. depends on whatever else is in the water as in any pollutants/chemicals/tree sap etc. the best answer is to call in a local electrician who will have the equipment to trace the problem. you could see what happens when the outside lights are disconnected from the timer ( both L and N need to be dissed).
Thanks for the reply, but when I flick the trip back on, it works right away, would it be water causing the issue in this case do you think?
It is the possible cause, but then again without an inspection it's hard to tell, if the fault continues then a visit from a local Electrician would be advised
Make sure you isolate (Switch the electric off) before you go opening box covers etc, at the Main Switch in the CU. Don't rely on individual circuit breakers as they will only switch the Live, not the Neutral.
Reply to Timed outdoor lights trip..then they don't? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi The ground floor of my house has two lighting circuits which are each protected by an MCB. One of those circuits is just indoor lights. The...
4K
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
