K
kung
Hi guys
Just a quick tip when i do rewires etc on unoccupied domestic properties i have a cu attached to a board with a double socket fitted that way you can wire into the cutout and plug fridge/freezer into it that way you can remove cu tails from old cu cutout supply and free's up wiring/cu to work on and leave overnight with no pressure !
Only thing is pitty they arnt all unoccupied !
unless the mother in laws chained to them
you could get the mother in law to channel the walls out with her teeth...
Hi
Tip number three don't fall asleep overnight because its no longer unoccupied.....
Regards​
Hi guys
I think that I’m missing something here,
If a property is unoccupied why would it have a fridge/freezer in it?
tip for doing unoccupied domestic rewires
Domestic Electrician Forum
kung,
Guest123,
