B
BluSparx
Hi Guys
just spoke to DNO who have advised me they don't hold any records for a property I am rewiring never had an issue previously.
Supply type is TN-S no earthing present been told that the only way the DNO will supply earthing is if the homeowner pays, surely if the supply type should have earthing the DNO are responsible for ensuring it is present
failing that I am going to need to install rod's but does anyone have any ideas how I can get DNO to install the earthing?
The DNO will always say that they are not compelled to supply an earth if they do its out of good will so to speak if its TN-S id still argue that the home owner thought they had earth as there was no label to suggest otherwise on the service head or anywhere for that matter and if someone would have been killed/inj as a result of their lack of eg DANGER NO EARTH SUPPLIED !eg TT
Anythings worth a try with them meet the fockers !
Hi Guys
If there is 'no earthing present' what makes you believe it's a TN-S system?
Depending on the age of the installation you may have found that the TN-S was not done by the DNO at the time but done by a sparks as a home made one, either by fitting a clamp on a lead sheath or picking up a utilities pipe, so there may not be a DNO record.
If the DNO have advised you that they are willing to supply an earth for you then chances are it will be PME, and to be honest I think they charge about 150+vat for this ,and much better than a TT IMO
Yep I am afraid this is correct I have mentioned this before that it should be a legal obligation by the DNO to supply a L-N-E within a specified limits but I have found 3 installtions in the past 2 months with an earth problem and the answer I get is we are not obliged to supply an earth ????????? but contact our new installs department and we will send a quote. What I cannot get my head around is that if I fail to connect a main earth up and somebody gets hurt I lose my card and can go to jail but a DNO can say we are not obliged.??????????????????????????
PS the same mentality goes for the main cut out switch I have a customer who is getting a new meter and he asked will you be fitting a cut out switch at the same time and the reply was no you want one you will have to pay. Now if he did not ask they would have terminated the single core 16mm red and black from the DB into the new meter ? Now how can this be right O and the question was asked do I get the switch fitted at a discount due to you already being on site and the reply was NO I do work for a letting agent and yes I charge a callout fee but I dont add this twice if I have 2 jobs to do so why should they
