Discuss TNC-S supply outdoors question. in the Commercial Electrical Advice area at ElectriciansForums.net
Just a quick question on something I came across today. Had to replace a door on a metal clad box in a car park that vandals have broken off. Inside the Metal housing was a 100 A main cutout TNC-S , a Meter and a small C.U. with two MCB's, One for a car park pay and display meter directly behind the box and the other MCB which fed another C.U. in another metal housing fed by SWA in a duct in the flower bed the other side of the car parking area. This C.U. then fed lots of metal lighting columns via timer and contactor ect ect. ..
My question being is this not the same principle as exporting TNC-S from your house across to a shed/garage and have the potential for the Metal objects to become live if there is a problem DNO supply side.? Or am I over thinking this. Where is the equipotential zone. Is it just within the first 500×500 metal enclosure?
Interesting. I haven't experience how this is designed in practice, but imagining from afar etc - I think swa armour for cpc should be ok, but likely not for bonding. So unless the down stream CU is set up as TT (gather not ?) then separate bonding likely required and is based on the incoming DNO neutral in accord with Table 54.8 - GN8 has an example on p70.
Yes the second c.u. is fed with a 2 core SWA using the armour as the cpu. Was just thinking when replacing the little earth bond fly lead from the box to the new box door that everything in this installation is metal the enclosures,the pay and display machine, ligthing columns ect. So fault current would try to find its way back through all these items if a fault occurred??
Reply to TNC-S supply outdoors question. in the Commercial Electrical Advice area at ElectriciansForums.net
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
I’m installing 20KW of Solar on my Barn roof, The barn is fed from a 3 phase supply originating at the house which is 80 meters away. I’ll be...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello everyone, I’m based in the ROI and live in a rural location. Yesterday evening my electricity supply started to switch on and off randomly...
Hi! I'm willing to build up a network within my residential house which includes outdoor equipment for WAN access. And I'm failing to figure out...
